10:41 PM
I posted a question about the AutoRouter earlier. I found out later that my definition of the "Width", "Drill", and "Clearance" in Net Class causes this problem.
I defined the Width, Drill and Clearance in the past, no any problems with AutoRouter.
If someone know how the Net Class definition relates to the AutoRouter (or RoutingGrid). I do need to define my power lines and GND to be larger than the normal lines. What I should to to avoid this error.
Dawn
