Polygons filling with lines instead of solid color
imechura
imechura
I created a board then I drew a polygon to lay copper copper into the empty spots of the board. It looks fine in eagle but whenever I print to a pdf then import the pdf into inkscape the polygon fill regions are filled with horizontal lines of color and white. I then exported the board from eagle to DXF, after which I imported the DXF into fusion 360. It took over an hour to import and after it was finished the board is made of of hundreds or thousands of line shapes in the polygon fill regions. Please advise as to how I can prevent this because its made this board/schematic useless for what I planned to do with it. Tried to attach files but the "browse" link does not open a file dialog.
imechura
Es tut mir leid, ich weiß nicht, warum dies im deutschen Unterforum gepostet wird. Das war nicht meine Absicht.
imechura
