12:33 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm almost done with this pipe support block but I've been stuck on this last bit for too long now. Hopefully one of you can tell me what I'm doing wrong.
As you can see from the attached dwg all the dimensional parameters are driven by a lookup table (pipe size) except the lower stem which can be sized as needed. the problem is the grip for this function falls out of position if you change it and the lookup value in certain combinations. It's a little erratic and I cant figure out whats driving it out of position. Any help would be appreciated.
