I found some "curiosities", e.g.
- compare the values of the insertion points (ID command) with the insertion coordinate in the entity definitions (10 x-value y-value z-value),
- compare the direction of the normal vector (210 ... )
Command: id
Specify point: X = 192914.740 Y = 3298083.254 Z = 0.000
Command:
ID
Specify point: X = 192921.631 Y = 3298083.254 Z = 0.000
Command: *Cancel*
Command: (entget(car(entsel)))
Select object: ((-1 . <Entity name: 1f5992609b0>) (0 . "INSERT") (5 . "BD1FD3") (102 . "{ACAD_XDICTIONARY") (360 . <Entity name: 1f5992609c0>) (102 . "}") (102 . "{ACAD_REACTORS") (330 . <Entity name: 1f599260d90>) (102 . "}") (330 . <Entity name: 1f5a7caf820>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "Textos Camaras") (100 . "AcDbBlockReference") (66 . 1) (2 . "*U385") (10 192915.0 3.29808e+06 476.08) (41 . 1.0) (42 . 1.0) (43 . 1.0) (50 . 0.785398) (70 . 0) (71 . 0) (44 . 0.0) (45 . 0.0) (210 0.000301248 0.00012673 1.0))
Select object: ((-1 . <Entity name: 1f599260aa0>) (0 . "INSERT") (5 . "BD1FE2") (102 . "{ACAD_XDICTIONARY") (360 . <Entity name: 1f599260ab0>) (102 . "}") (102 . "{ACAD_REACTORS") (330 . <Entity name: 1f599260ed0>) (330 . <Entity name: 1f59fc8d1e0>) (102 . "}") (330 . <Entity name: 1f5a7caf820>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "Textos Camaras") (100 . "AcDbBlockReference") (66 . 1) (2 . "*U385") (10 -2.96533e+06 1.45619e+06 -29958.1) (41 . 1.0) (42 . 1.0) (43 . 1.0) (50 . 1.95798) (70 . 0) (71 . 0) (44 . 0.0) (45 . 0.0) (210 -0.0189598 -0.00797444 0.999788))
and also
- have a look at the attached image.
... a never ending chaos 😞
I think the objects (the whole drawing ?) have a long history and also the dwg was not created with AutoCAD.
Perhaps the block definition was redefined in the past? But I can neither say what really causes this problems nor how the file could be to repair. Sorry, I can not help.
Jürgen Palme
