visibility
visibility
stavjan19989
visibility
stavjan19989
Hey 🙂
can i do 2 visibility in one block?
If not, then I need to use 4 positions to control the disappearance of 2 objects? And 8 poses for 3 objects?
chrismunt
Hello.
I am struggling to understand your question, sorry. But the simple answer is yes. You can have multiple visibility states.
What are you trying to do exactly?
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
stavjan19989
I want to work in a block, I want a cube to appear on the side of the block as needed, and in addition a round will appear at the bottom of the block if necessary. I want the outside of the block to be written: "cube" yes/no. new line "Circle" yes/no.
So I managed to create one of these but when I try to create a second one it just doesn't happen..
Thanks for the help
chrismunt
Again, still struggling to understand. Pictures of the desired outcome or a .dwg file of what you already have can be very useful. My best guess is you would need 4 visibility states.
1. A default state of showing just the block, no additional cube or circle:
2. Cube (showing the block, with additional cube)
3. Circle (showing the block, with additional circle)
4. Cube & Circle (showing the block, with both additional cube & circle)
See attached the .dwg file of this example block. Is this the kind of thing you are after?
stavjan19989
Ok, really thanks for the help ❤️
chrismunt
You are welcome. If this is not what you are after I am happy to help further. If this does resolve your issue please can you mark my post as accepted solution to prevent others helping you solve a resolved issue.
