Visibility States Dialogue Box Doe not Appear
John_Moss_1964
John_Moss_1964
I have been using the same computer and AutoCAD version for several months. I use dynamic blocks extensively. Yesterday I was creating a basic dynamic block that would have a few visibility states. I add the visibility parameter and then click on the visibility sates button and the dialogue box no longer appears and all the other buttons on the ribbon are greyed out as if the command is operating. I also checked with an existing dynamic block that had multiple visibility states and I clicked on the button and the same thing as mentioned above. I saw nothing in the help menu that addresses this articular problem. Any ideas?
h_s_walker
Have you used two monitors recently?
If so plug in another monitor again and see if the Visibility dialog box appears on that screen and then move it to your other screen.
Howard Walker
Left Handed and Proud
John_Moss_1964
I use 2 monitiors and a laptop. I unplugged and replugged. I tried all monitors. Still nothing
h_s_walker
Hold down the ALT key and then press the SPACEBAR. Does a menu pop up? If it does select MOVE and then use the cursor keys. Try up and down first and then left and right. You might have moved it up the screen or down.
Howard Walker
John_Moss_1964
Thank You. That worked
