visibility framework around dynamic block
How can I change visibility of framework around dynamic block.
In one drawing it is not visible, what i want, and in the other drawing it is visible, see second picture.
It is the same dynamic block in two different drawings.
Libbya
Is there a wipeout in the block?  WIPEOUT command and turn on the frame?  If that's not it, then post both FILES.  Images are fairly useless in comparison.
vinodkl
Right click on the block and select "RESET BLOCK" which would reset the block. Try this on both the drawing. Does this solve the problem? If not please attach your block so that we can look into it.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
