I have some free time on my hands towards the holidays so I'm trying to consolidate my company's blocks into a single database as we have one for each scale we use. I keep running into problems everywhere I turn.
In the attached picture, I'm trying to modify this existing 4' linear block. I need it to adjust the lengths of the ends, the circle size, and stretch the right line while maintaining the overall length of the block and the left line based on annotative scale, dimscale, etc. In my most successful attempt, I made the ends and the circle as annotative blocks within a block and used a bunch of constraints.
However, ACAD is so limiting in this regard and I couldn't constrain the right line to the circle's quadrant. I even placed a defpoints line in the circle block (so that it will scale with it.) This actually works fine until I make that block annotative. Then, the right line will either not adjust to the circle at all or the constraint will default to the center of the circle. Going into the master block, the constraints will no longer snap to the circle's block at all, but it still shows them there.
I've exhausted every idea I had and now I don't even know if it's possible.
