Using Dimensional Constraints to define distance between two lines
Hopefully this is quick and obvious; I just want to use a dimensional constraint parameter set to a constant value to maintain a distance between two lines as other lines around it are stretched dynamically. When I add the constraint it defaults to d5=0, I type in d5=.125 and hit enter and the expression field in the parameters manager updates to .125 but the value remains set to zero and the constraint is still displayed as d5=0. Any insight on this is greatly appreciated, I am sure there something missing about how these constraints are meant to work. Thanks!
vinodkl
What is the precision set in "UNITS" ? is it set to "0"?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Libbya
Post the block.
Why would you need to add any constraints "in order to maintain a constant distance between two lines while other lines are stretched around them"?  Simply don't stretch those two lines in different ways.  In 90%+ of cases, using constraints in dynamic blocks is unnecessary and causes more problems than it helps.  In 98%+ of cases, adding constraints to dynamic blocks WITH dynamic parameters/actions only causes problems.
Post the block.
Yes that was it, thank you very much. i knew it would be something simple!
IT dept might not be happy with me posting a .dwg with a block that one could potentially gleen product info off, but thank you for that advice. I think the issue is that I'm not stretching the block (I know that's what I said before, misspoke)  but rather I have a block table that drives changes to my outermost line but it behaves unexpectedly and the relationships between the other lines that I don't want to move isn't maintained, hence the reason I am adding constraints.
Fairly new to ACAD coming from Solidworks and Creo, so I am kind of working throught this dynamic blocks stuff
Libbya
Your description sounds like the block would fall in that 90% category where it would be more effectively made without any constraints and with only the use of dynamic parameters/actions.  The benefits would include more consistent behavior, smaller file size, reduced load on computing resources, etc...
