two-pol electrical switch
syanchuck
syanchuck
Trying to create on two pol switch two positions: On and Off.
OFF PositionOFF PositionON PositionON Position
How to create two different positions without using Visibility?
Thanks in advance!
Libbya
Flip, or rotate+lookup, or stretch+lookup, etc...
Images aren't particularly useful.  Post the block instead, if you want further assistance.
syanchuck
Thank you for your response.
Here is the block.
Thanks!
Libbya
Flip seems to be the easiest way but you have the line in the wrong place.  Is there a reason this doesn't work?
syanchuck
Thank you very much! I will check it later today and then I will accept your solution and if I have a questions, I will ask.
syanchuck
I am trying to understand, what I need to do.
From you clip I can see that you deleted the Flip State and the you created the new on in the middle point of the distance between similar contacts.
I am trying to repeat it, but something doesn't work.
syanchuck
Actually yes, I did it.
Thanks!
