Trying to create multiple dynamic blocks
jim3thornton
jim3thornton
We created a library of Dynamic Blocks.
The Blocks range from 5x5 to 10X30... so about 10 varieties total.
The problem we discovered was that the initial dynamic block was named 5X5 and every block after that was also defined as a 5x5 block even thou the individual block files are named per size.
We had tried to interest the blocks, either through insert, drag and drop or tool palette... every block will take take the image of the first block that was inserted.
Is it block to edit the block name within each of these block files?  rather that start over?
jim3thornton
RENAME ... A quick look after posting this and I found the command RENAME addresses our issue
