TITLE attribute I need it convert from single line text to multi line text
MatTheDrafter
MatTheDrafter
I created this generic block to title viewport with their scales.
Most times it works perfectly, even made it dynamic so I can extend the line below the Title when required. Sadly ran into a situation that the Title is way too long for the viewport and the rest of the drawing. Do I need to make a new block with Title as multi-line txt or is there a short cut to make it double line text?
Libbya
You can add a visibility state and have a multiline attribute in the second state.
MatTheDrafter
How would I go about doing that?
Libbya
There are quite a few free videos on Youtube that cover Dynamic Block basics like visibility states.
MatTheDrafter
Would that allow me to keep it to one block or would I need to have two blocks? One with visibility and one without?
MMcCall402
Open the block in the block editor and select the Title attribute.  In the properties window you should see a line tiem for Multiple lines. Set it to Yes.  Save the block.  Run ATTSYNC to re-sync any inserted blocks with the modified block definition.
Also, edit the justification to be Bottom Left. That way the text lines will stack Up and not down.
Observation:  This doesn't need to be a dynamic block. It could be MText with fields and an underline.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
