Text that can be arrayed and mirrored in a Dynamic Block
06:01 PM
Hi Forumers,
I was wondering if there was a better way to array text within a block.
I've managed to make an adequate block with text that can be arrayed and can accommodate a mirror action using MTEXT. But if you mirror the block and use the flip function, then try to array it, the text appears outside of the block.
Can this be changed so that it doesn't appear outside of the block? Also, is there a way so that when you mirror the block with text as MTEXT the text doesn't flip?
Also, is there a way for the text to be an attribute and be array-able?
Note: MIRRTEXT = 1 for flip function to work
Thanks in advance,
