Text orientation on rotate
joe_kohli
joe_kohli
Can someone help me with the text orientation of this block that I created? I want to be able to incrementally move the tail by 90 degrees while maintaining the text orientation as followed in my picture I attached. I have attached the block so that you can see how it polar stretches and rotates.
h_s_walker
If it was multiline text it would be easier as the justification for multiline text always flips, so you can be sure that your text will not go over the line.
Howard Walker
Left Handed and Proud
joe_kohli
I really only need single line but is there a way around this? (Hiding part of the multiline text)
h_s_walker
Not that I can think of off the top of my head
Howard Walker
MMcCall402
It can still be a single line of text even though its a multiline text object type.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Exevium
You can cheat by using a dimension, and replace the contents with a field.
