I have created a group of blocks for notes with leaders. We often have to rotate the blocks to get them to fit in spaces available. Now an issue I have run into is that we often need the leader on the other side. (eg. leader comes out of left side of the block, need on right.) Now I can add the functionality to flip the leader. But I am looking to keep the usage of the block as simple as possible. We can only have the text at a rotation of 0 & 90.
So after all that explanation of that I'm doing. Here is what I am looking for. I want to set the text so that the text will display as normal for rotations of 0-90 degrees, but if you rotate beyond it will flip the text as o keep the bottom of the text orientated toward the bottom, bottom/right of the drawing.
If that makes sense, is there a way to do this?
