Text Field Attribute showing ##### not custom field
dpeake1981
dpeake1981
       I've created quite a few dynamic blocks but I have decided I want to add a label to the block. I have added a attribute that in turn references a custom Field from the Block Table. However when the block is used it only ever shows ########. Any ideas?
ojuris
Hi
you must set for attribute in properties Constant to No
better solution I think is not add field in attribute but add attribute in table (I add block Aluminium Angle 2). In this case you don't need to use Regen after changing block
