Swing on Door Elevation Block Not Staying Centered Vertically
estringer
estringer
I am creating a door elevation block that changes height and width but I am having issues with the swing indicator. It is not staying centered vertically when the height is adjusted.
h_s_walker
Remove those lines from your main stretch action. Add another stretch action to your vertical distance parameter. Make sure you only put the crossing selection around those two lines. Change the distance multiplier to 0.5.
See the image below
Howard Walker
Left Handed and Proud
estringer
That helps with the original problem but now the top line at the top right corner is not stretching with the rest of the frame.
estringer
Okay, I added another stretch to that part and it works now. Thank you for your help!
