Stretching issues in blocks
braicodavid
braicodavid
Hi everyone,
Just wondering if anyone knows how to fix a stretching issue in blocks. I have a fairly simple block where one component is a rectangle with hatching inside. I am able to get the rectangle to stretch but the hatch pattern just moves without stretching. What's am i doing wrong?
Erense
Most probably you have selected the 'centerpoint' of the hatch with your stretch selection. That way Stretch is converted to Move. Also make sure you hatch is associative.
Otherwise attach you block so we can see/try to fix it.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Libbya
Post the file.
braicodavid
Thanks for your help guys. I managed you figure out out. The hatch was associative but I was picking the hatch by boundary. I instead hatched my object by using the Select Boundary Objects and that seemed to fix it.
