Stretch and move plus stretch and move.
Tee.Dee
Message 1 of 9
Tee.Dee
Sorry for the title not sure how best to name what i'm trying to do.
.dwg attached which is a representation of my actual block.
What I would like to do is have a single grip which moves the green, yellow and red squares a certain distance and stretches the branches of each, so far I've managed to achieve this much.
This is where i'm having trouble, What I would also like to do is once the green and yellow reach their maximum positions I would like the red square to keep on moving until it reaches the blue line to the far right.
Thanks!
Replies (8)
Message 2 of 9
Libbya
See step-by-step screencast in followup post.
Message 3 of 9
Libbya
Message 4 of 9
Tee.Dee
Thanks Libbya!
Now to get my head around look up tables.
And sorry for the new thread, only reason I did this was because the original obviously wasn't getting much attention probably due to the bad title hence recreating it with something more relevant 🙂
Message 5 of 9
mehrdad.rahimi.en65
Hi dear friend, you have two types of tools in your pallet that I had never seen before. How can thriple lookup and double lookup be created? The solution you provided cannot be implemented without double lookup.
MeHrDaD RaHiMi
Revit Architecture Certified Professional
Revit Structure Certified Professional
Message 6 of 9
vinodkl
See this :How to Make a Double Lookup
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 7 of 9
mehrdad.rahimi.en65
Thank you, actually I had made one(Double Lookup) but I didn't know (BACTIONBARMODE) and didn't use it. It is so good.
Now Please explain about the numerical structure you entered in Distance field in Lookup1. And if we want to do this for a three-piece telescope piece, how do we enter the field Distance value?
MeHrDaD RaHiMi
Message 8 of 9
Libbya
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoC...
That list is mostly correct, but is wrong where it says that (,5) is a value greater than 5 and (5,) is a value less than 5.  Those should be reversed.
Message 9 of 9
mehrdad.rahimi.en65
thank you dear friend. it is what exactly that i'm looking for.
MeHrDaD RaHiMi
