Strech Threaded rod
Strech Threaded rod
Message 1 of 11
Strech Threaded rod
I want to stretch the threaded rod to infinite please find attached drawing and let me know how can I do that.
Accepted solutions (3)
Replies (10)
Message 2 of 11
Libbya
Is this infinite enough for you?
Message 3 of 11
h_s_walker
Or you can have this which stretches from 2 lines onwards
Howard Walker
Left Handed and Proud
Message 4 of 11
Thank you very much. it's really helpful.
Message 5 of 11
I want to start from 1" that's why.
Message 6 of 11
Libbya
You can actually get it down to a single linear parameter and a single increment along with making it a more accurate representation (threads would bind on the flat edge shown previously).  😛
Message 7 of 11
Libbya
If you want it limited to 1", then the first screencast I posted should be exactly what you are looking for.
Message 8 of 11
hi Libya,
I am trying to make threaded rod as you suggested but I am getting difficulty for 1-1/4" thick one. I'll attach the file please look at it, u will understand what is the difficulty.
Message 9 of 11
Libbya
The 1-1/4" size will not array correctly because of a rounding error.  You can't see the rounding error until you set the luprec system variable higher.  See screencast.
Message 10 of 11
Hi Libbya,
I have set the luprec variable up to 8 but again I am getting the same problem with 1/2" thickness. I have attached the file please look into it.
Message 11 of 11
Libbya
Here you go.  It's a good rule of thumb to always use the little quickcalc dialog for setting specific increments and array column offsets and use the 'Apply' button.  The main issue, though, was that the linear parameter associated with the array was not set to be chained.
