Message 1 of 9
11:40 AM
Attached is a Storefront design. Fairly intricate, but easily thought through. It's stretchable, with a Visibility dropdown for Panes and Mullions.
In the CAD file, is an additional block (It's an array path, inside a dynamic block), that utilizes constraints to limit the size of the Panes. I'm trying to combine these two blocks, so that I can eliminate most of the Dropdown and make the execution of the block much simpler.
ie, pick the amount of mullions, and just stretch the storefront to the Rough Opening.
I having difficulty understanding how to create the Distance Expression for the Array path.
Thanks!
