Staggered array?
Staggered array?
Message 1 of 8
Staggered array?
So I have a few questions regarding dynamic blocks. I have set up these blocks so they have an array function on them. So they can array in columns and rows. I am wondering if there's a way to have the rows stager in a traditional pyramid? Like can you take row 2 and add in half of the width of the block of free space and decrease it by one block? Or does anyone know anything similar to this?
Replies (7)
Message 2 of 8
h_s_walker
Highly doubtful, because your asking it to offset and add rectangles at the same time.
Lisp might do it, but since you originally posted in the LT forums I assume you don't have full AutoCAD so that wouldn't work anyway.
Howard Walker
Left Handed and Proud
Message 3 of 8
ojuris
how much rows you need?
not the most elegant way but can be done with visibilities and double lookup
Message 4 of 8
1-6 rows
Message 5 of 8
h_s_walker
See the attached drawing
Howard Walker
Message 6 of 8
That is exactly what I am looking for @h_s_walker is there any way you could lead me to step by step instructions of how you achieved that?
Message 7 of 8
h_s_walker
First I made six visibility states, one for each row.
Then I added a linear stretch and put a point on the defpoints layer and used the  stretch to move that point. I only put the point on there so the arrow on the stretch would be visible.
I made the stretch incremental at 0.5 spacing with a minimum of 0.5 and a max of 3 (the rectangle I've drawn is 1x0.5)
Examine the double lookup it links the distance with which visibility state will be shown.
Howard Walker
Message 8 of 8
Dibble_Engineers
Community Visitor
Community Visitor
I have used ARRAY command and then adjust the INCLUDED AXIS ANGLE to 45 degress in properties.Array with staggered offsetArray with staggered offset
If I am going to stagger vertical like nailing patterns, then ROTATE array block 45 degrees as well as INCLUDED AXIS ANGLE.
