Spontaneously moved attribute
I have problem with my dynamic block. I opened my drawing yesterday and some dynamic blocks was displayed wrong. Some inserted blocks in drawing don't match with its definition. Attribute is spontaneously moved, see attached drawing. This problem occurs only block, which I use flipping, blocks with not flipped state are correct. Reset block helps but there are a lot of blocks to fix with this method.
Thanks, Marek
Libbya
I have noticed similar behavior at times and have found that restarting AutoCAD fixes it for me.
To restart AutoCad doesn't work in my case. But I found out this: It's happend when AutoCAD crashs and drawing is recovered.To fix it I have to change attribute parametr "lock position" on "NO", then all blocks are correct, finally I return lock position on "YES" so that block works right way.
