Spacing multiple v notches at an equal distance based on a lengths...
I am editing an existing dynamic block, trying to do the following: Add in a set number of V notches at an equal distance based off the total length.
The block is currently setup to stretch from 10-12', I would like to add in 3 v notches spaced at an equal distance for all length (10', 11' & 12').
So I want the length of the v notch to be at a distance of (Total Length)/4, but I'm not sure how to enter this in...
Thanks!!
Libbya
Post the block.
Please see attached block.
Details posted above are for the Type 3 only (3 v-notches equally spaced), Type 2 will have 4 and Type 1 will have 6. If you could lead me in the right direction with the first one that'd be great.
Thanks!
Libbya
See the attached screencast.
Thank you very much for the screen cast, this is exactly the help/guidance I needed!!
