Snap objects to the end point
vladop
Advisor Advisor
Message 1 of 21
vladop
As seen in the attached video, using the stretch action with the point parameter and vertical constraint I achieved that when stretching the vertical line remains vertical and that the bottom point of the vertical line remains at the same height.
(view in My Videos)
How do I make the attributes and geometry along and below the vertical line move as if they were glued to the bottom point of the vertical line.
It doesn't help if I include these objects in the stretch action, because if the stretching is done up or down, then the objects also go up or down, they remain aligned with the bottom point of the vertical line only along the X axis.
I had the idea to fix the second point parameter to the bottom point of the vertical line, set the chain action to YES, and then add a move action for all objects that should remain glued to the bottom point of the vertical line. I haven't found a way to fix the second point parameter to the bottom point of the vertical line.
Maybe there is another way?
Attached is a drawing with a block.
Accepted solutions (3)
Replies (20)
Message 21 of 21
vladop
As far as I understand, dynamic blocks only work in their own coordinate system and it is not possible to connect them to the block insertion point, block rotation, etc.
