Simple dynamic section symbol that I can't get to work
nilswa
nilswa
Hi am trying to understand how I can make my simple section symbol rotate the hole thing while still being able to only stretch the line. The text should also rotate with the rest. Not sure what I do wrong here
jmendezicce
you have some errors in your block, i hope this help you:
you need to move the block in the point to begin the parameter polar dimension.
this is the area to select strech element.
moved the dimension that defines the size of the section to the origin of the block
and finally i delete the constraint do you have in this point
i attachment the file
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
Si esto ayudó a resolver su problema, recuerde "aceptar como solución" para ayudar a otros a encontrar respuestas.
