Show parameter as text
tomislav.markovinovic
Observer Observer
Observer
Observer
I want to insert (use) one parameter in block table as a text (please see attached). How do I do that?2023-04-26 14_32_50-.png
Thanks.
pendean
Community Legend
Community Legend
"text" is too generic a term: as you wanting a FIELD so there is a relationship to whatever it is in what looks like a table is always referenced? an Attribute? Or something else?
Otherwise, if you just want "text" you can just type that in there.
Let us know your final intent and what it is you are creating (sample DWG file will all relevant content is best)
Libbya
You can change the 'Type' of parameter within Parameters Manager and make it 'String' for text.  It looks like other values for that parameter do show text, so as Pendean mentioned, you can just type it into the appropriate cell in the table.
Observer
Observer
I suppose it should be attribute (in leader). I want to display value from table to be visible in a leader. I hope it is clear what i mean..?
jtohillVY4VS
It looks like you are picking the area from the table. You could pick the object and choose the area of that object as a field.
