Sequential alphabet and numbering attributes
Hi....I have a block with one attribute to rename axes ... Could i auto numbering and alphabeting the attributes ?!!! and if i change any number or remove any axe could the others changed automatically Smiley Happy or i shoot the moon.
any one help !!!!
Libbya
If you are wanting to auto-number sequential insertions of the same block then I am not aware of any way in AutoCAD aside from getting into coding.  In AutoCAD Architecture (and probably other verticals) you can auto number blocks using the property set definitions.
If you are wanting to auto-number sequential items within a single block then it is certainly possible.  Post the block and I will attempt to help.
