SCALING PEDESTALS UNIFROMLY BUT TO BE IN POSITION
coolkris
coolkris
hI,
I am trying to make foundation pedestal plan dynamic blocks,
Where I need to change width and height of footing A & B (achieved through stretch).
Also I need to place the pedestals a1,a2,a3 (horizontally) & b1,b2,b3 (vertically) (achieved through stretch).
I need resizing of pedestals  so I tried the scale parameter and apply to other 3 pedestals that uniformly scales other 3 pedestals. But the location of pedestals move away from the positions.
How to fix this.
Krishna
Libbya
Use a scale action for each footing.  Set the base type of each of those scale actions to independent in properties and move the new base grip that appears at the basepoint of the associated parameter to the location on the footing that is appropriate for the scale action.  You will then need to add those scale actions to the selection sets any actions that move the footing that it scales.
coolkris
thanks so much, I have successfully done that, I have problem in aligning parameters after stretch.
How to keep in line all the marked up parameters and associative dimensions
