Scaling annotative hatch
martin.mardikas
martin.mardikas
Hi!
I have dynamic block with annotative hatch.
If i enter block into drawing and ex. i have set annotative scale to 1:50 before. The hatch doesn´t change to 1:50.
Is there a way to change that, so that if i enter block the hatch scale will be according to annotative scale?
Best!
h_s_walker
@martin.mardikas You can add scales to the hatch object. See the first image below. However do note that when you go into the block again to edit it, the hatch will always display with the largest scale that you added. I added all the metric scales to the hatch and as you can see in the second image the hatch is displaying at 1:100
Howard Walker
Left Handed and Proud
rosie_lucas1
Hi @martin.mardikas,
Did the info from @h_s_walker help answer your question?
If it did, it’d be great if you could click the "Accept Solution" button so others can easily find it too.
If you’re still needing more help, feel free to share an update here. The community will be happy to jump in with any next steps to help you get where you need to be.
Best,
Rosie | Community Manager
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Rosie
martin.mardikas
Thank you for advice!
