scale a block
scale a block
bdemirQDGWN
scale a block
bdemirQDGWN
hello everybody,
i have a specific question about (dynamic) block scaling. Is there a way to scale the block without changing dimensions of it. So i want to scale it but i want to also keep the custom. This is important to show the correct info in a table.
thankyou
kind regards,
Beyza
h_s_walker
No unfortunately not the way you are asking. The dimensions / parameters will always scale with the block.
Why not make the block annotative and then add all the scales you are using in your viewports, then the block will show at the correct scale in the viewport, but will keep the dimension you want.
See the attached drawing. The viewports are all different scales. Yet you will see the block shows the same size in all of them.
Howard Walker
Left Handed and Proud
bdemirQDGWN
Hey hwalker, thank you so much. I understand the logic. 🙂
