Rounding an attribute down
samuelb8Y56V
samuelb8Y56V
I'm not perfect with my terminology as I'm fairly new to dynamic blocks. I've successfully made a block which allows for various racking dimensions that can then be arrayed along a line but wanted to add a way to count the number of bays in a run, which I currently do by hand. I have gotten fairly close in that the attribute displays the number of bays but I want it to round down as I can't have 0.789 bays, yet my attempts of using ROUND and ROUNDDOWN have had little affect or produce a ####. Any explanation or edit to the attached dwg would be so useful as the work I've done so far has been fun.
h_s_walker
1. I would change all your distance parameters to increment (see the first picture below) to make sure you don't have a distance which isn't a bay length.
2. Change the precision of the formula to 0 decimal places (see the second picture below)
Howard Walker
Left Handed and Proud
samuelb8Y56V
Perfect took me some tries to get the formula to save the settings, but got there in the end. Thanks
