Rotation Parameter
Rotation Parameter
johnkelly60
Rotation Parameter
johnkelly60
I can't seem to get the rotation to right angle...I have 4 visibility states, and I want 3 of them to rotate on 90 degrees increment....I don't know what I'm doing wrong...Can someone help me?
Libbya
Your block seems to work fine and both rotations work with 90 degree increments like you say you want.  Please give more details on what the issue is.
johnkelly60
Hmm...when I re-inserted the block, it works fine...that's so weird...
When I edited the block in the drawing and set the rotation angle to be "increment", after saving the block it didn't rotate on right angle. (shown attached image) That's why I was so confused why it wasn't working.
Brock_Olly
It's good practice to rightclick -> reset block after you've applied some changes.
