05:43 AM
Hi All,
I have created dynamic block with visibility stages, which you can control (switch to) using triangle grip on the bottom. Both visibility stages consist of 2 separate "inner" blocks. The one which is relevant for visibility stage called "Directional" (block name - "Aquasquare_Trimless_Arrow") got rotation feature with circular grip on the right which allows rotation (parameter/action). Rotation feature works only if this block is not inside of another - outer dynamic block. When I use it as part of dynamic block (as inner block or sub-block) this rotation feature is disabled. Could someone please explain what causes this issue?
Many thanks
Peter
