Rectangular array - any helpful lips?
Message 1 of 1
Hello guys!
Someone suggested me to post to this forum too.
So I would like to use the rectangular array command like a pro.
Let me tell the story: I have a layout of a house (from top view of course). I have the walls. I would like to distribute the lamps inside the rooms, but with conditions.
I would like to tell the program  ranges as measures not exact sizes.
Like: the lamps should be 1000 mm from each other at least, but maximum 3000 mm. The distance can change in this range (from 1000-3000 mm) but only with 100 mm steps. (So no 2987,35 mm)
Also I would love if I can order to the program that the first lamp from the walls must be at least 200 mm away,but not more than 2000 mm. This can be fraction number.
Is this possible?
Now I do all this in a lot of steps, I would like to find a faster way.
Thank you!
Replies (0)
