Problems with stretch action
Attached is a dynamic block I am working on and having some problems with stretch action.
On the right side you see a place where a person places no., revision/issues and date here, I would like to add a stretch action to add more lines incase more than two revisions are needed.
I tried using the linear dimension and stretch action but no luck.
Here is a link what I would for the revision part. https://www.youtube.com/watch?v=mSrIhgDucs8
Can anyone fix this for me
h_s_walker
Here you go. I changed it to an array so that the lines will appear as well. I also added a stretch to stretch the vertical lines.
Howard Walker
Left Handed and Proud
Hello hwalker,
I have been struggling with this for awhile and was wondering can you do a screen cast on how you got this to work.
h_s_walker
Unfortunately I don't have screencast (office policy) so I can't show you.
So instead I'll try a step by step
1. Remove Distance 3 and Stretch 2 totally.
2. Add a linear array starting from the second line up and finishing at the top line.
3. Add the top line to the linear array.
4. Make the column array distance 3/8"
5. Make the minimum distance of the linear parameter 3/8" and the maximum 1'-1 1/8"
6. Make the linear parameter distance an increment of 3/8"
7. Add a stretch action to the linear parameter and add the two vertical lines to it. The stretch box only needs to encompass the top of the two vertical lines.
Howard Walker
Thanks the steps were really good.
