Possible Block Fix or Hatch
gottfriedjoseph01
gottfriedjoseph01
I'm trying to create hatches that match the cell blocks in the attached drawing. I need to know if what I'm trying to do is possible. I want create hatches that match the array. A block at each end of the line and filled cells that are arrayed 12" 16" 24" and 48" on center. The array should be divided because in it almost impossible to get the blocks to be 16" on center exactly. Measurements 1-3 9-16" is acceptable and preferred. I also have floor trusses shown in green would this possible for floor trusses?  If this could be a dynamic block even better. Any advice would help thank you very much.
MMcCall402
Are you looking to have the arrayed blocks at exactly 12",16", etc with a block at the beginning and the end?  or a variable even spacing of the blocks with 12", 16", etc used as the maximum spacing?
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
lauri_barnhart
Hello @gottfriedjoseph01, we appreciate you posting your question.
Did you happen to see the questions posed by @MMcCall402?
Are things working as expected now or are you still needing assistance?
If the issue persists, let us know with an update so we can assist further.
Best,
Lauri | Community Manager
gottfriedjoseph01
Variable even spacing with the values given as maximums, with a block at each end.
lauri_barnhart
Hello @gottfriedjoseph01, thanks for posting in the community!
Just checking in - has your issue been resolved?
If you've resolved this issue, please share it. It will help other community user find a solution to similar problems.
In case you still need help, please provide an update here so we can help you best moving forward.
