Message 1 of 10
Polygon Offset Lock
04:46 PM
I’ve been trying the different parameters, actions and constraints but have not found a solution to maintain a defined offset on a polygon.
I created a rectangle that can be stretched on the X and Y axis, is simple and does the job.
The problem comes when we have to use different angles (other than 90*). At that point the two polygons behave differently, and the 1" offset is lost.
Can you please help, attached is the file with the original dynamic block (left), to the right is the block that I’ve been working with, below it is how it should look.
