Point Parameter
Point Parameter
Titanium5
Point Parameter
Titanium5
I'd like to know if it's possible to use the point parameter within the dynamic block to later dimension to once placed in a drawing? if so, how?
Libbya
No, none of the dynamic parameters have snap points when the block is inserted into model space.  You could add a point (POINT command) to the dynamic block at the location of the point parameter and on a non-plotting layer, though, and then add a move to the point parameter so it moves the point entity.  The result would be the same.
Titanium5
Thank you 😉
