Not visible attribute definitions at other visibility states
Sandervp
Sandervp
Hello everybody,
I have created a dynamic block with several attributes and 3 visibility states.
On top of every visibility state you'll see 2 attribute definitions. But this is only correct at block editor. If I change the visibility into another, the attribute definitions are also changing from place.
After closing the block editor, the attributes of the first visibility state (standaard) are placed correct. But do I change the visibility state into the second or the third one, the attributes doesn't appear. The only top attributes you'll see are the one from the first visibility. Using the attsync command doesn't solve the problem.
What is wrong?
Is it also possible to use only the 2 attributes definitions on top of the first visibility state for the other 2 visibility states? So I do not have to use 6 attribute definitions?
visibility states:
first= standard length (standaard)
second= extended length (verlengd)
third= extra extended lenght (extra verlengd)
ojuris
hi!
try this
