Announcements
Non-Annotatice dynamic block inserts as Annotative
dvertz
dvertz
I have the attached block that has all objects in the block set to have Annotative property set to NO. And when you open the block editor and go to properties, the block is has Annotative set to NO. But when I insert the block into a drawing, it comes in as Annotative set to YES.
Can anyone explain what is going on with the block? What am I missing?
Civil 3D 2022,
Windows 10 Pro, x64, Nvidia Quadro P1000
Intel Core i9-11900k; 3.50GHz, 32 GB RAM, 500GB WD BLACK M.2
Replies (7)
h_s_walker
It inserted as non annotative for me. See the attached drawing. I saved the block as test and the image below
Howard Walker
Left Handed and Proud
dvertz
This is one of those cases that always bugs me. Where something works one way on one machine and completely different on another machine. I opened an new drawing and checked it again. Wanted to be absolutely sure as I had been playing with three similar blocks (one annotative, one dynamic and one non-annotative).
Here is my screen capture: See the Annotative property?
And then I downloaded the one you had attached. I got the same result ... Annotative!
Civil 3D 2022,
dvertz
OK. Further tests ....
I renamed the drawing and to test as you did. It inserted non-annotative. So I started thinking maybe my template already had the G-CAL-DYN.dwg inserted. I checked. It does not. Why would changing the name make a difference if its not already in the drawing as that name?
Civil 3D 2022,
dvertz
Sorry,
Too many copies floating around now. When I inserted yours, one of mine must have been in the drawing. As when I checked it a second time, I got both blocks as you have in your screen capture. And when I restored the name and inserted into a clean drawing, it came in annotative with both blocks in one. That's when I opened your drawing instead of inserting into a drawing and found you had the original drawing open when you inserted the block into itself. How confusing for me. Still your drawing or mine, it still inserts annotative for me.
Civil 3D 2022,
h_s_walker
Ok so it looks like the default for inserting a drawing as a block is to make it annotative, which is why I didn't see your problem
The way I work with blocks is make them inside a container drawing, and then use a tool palette where I have them all showing to insert them into the drawing.
Howard Walker
Libbya
When I downloaded your original block file, the properties said it was not annotative, but when I inserted it into a blank drawing, it inserted as annotative.  I can confirm your issue.  However, I then opened your block file again, changed its annotative property to Yes, saved it, closed it, opened it again, changed its annotative property back to No, saved it and closed it.  After that it inserted into a blank drawing as non-annotative.
dvertz
That worked for me too. How odd.
Civil 3D 2022,
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
