Multiple Stretch actions for Multiple Arrayed Objects in Dynamic Blocks.
lakshmankumar.satya
lakshmankumar.satya
I tried to make dynamic block for my furniture that is cabinet with legspace for time saving i need to add array parameter.When i try to array the cabinets including legspace the arrayed objects are not comming with other stretch parameters.what i need is when im going to array the blocks should come with multiple stretch parameters cos for space constraints i need to change required dimensioned block and also the continuity block should move along with stretch parameter.Please do the needful.
Libbya
It's a bit hard to understand what you are asking for.  You cannot array parameters/actions.  Each arrayed object(s) will always be the same as the original object(s).
MMcCall402
Are you saying that you would like to array the cabinets and then have stretch parameters/actions for each arrayed cabinet?   An array won't allow that.
If that is what you wanted, look into using visibility states for choosing how many cabinets. Each state could show only the parameters relevant to the objects displayed.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
lakshmankumar.satya
Thanks for your reply.Yes i would like to array the cabinets and then have stretch parameters/actions for each arrayed cabinet.Using visibility states for choosing how many cabinets is not possible on this state because furniture arrangement depends on room size and i have to match the furniture+Leg space with that dimensions.If any chance could you guys help me with any other solution for my requirement.
lakshmankumar.satya
Thanks for your reply. why cannot we array attribute/parameters/actions.If this feature available our works will go well and saves a lot of time. But now same old work flow again. Autocad people should have to work on this type of update.Because in fast track projects, copy/paste commands leads to delay the work.
Libbya
Why can't you array parameters and actions?  Because simply do not work that way and I doubt they ever will.  Tough luck.  Here's a complicated way to simulate what you're asking for.  Add as many as you want.  It's a lot of work to make the block, though.
