Please help with any ideas how to fix the attached rack aisle block. I have set up dynamic blocks so the product depth changes on the racking as shown, the dimension1450 should not change nor the 350 dimension,I want when the product depth changes that the racking moves also so that it always maintains 350mm from the new product depth. For example if you change product depth to 1500 then the distance between racks becomes 3300 = 1450+1500+350. Two other constraints I have are 1. that the the racks move to each side so that the overall block stays centred down the middle of the 3000 aisle dimension and 2 that if the product is less than 1200 deep then the racks do not move and stay at 3000 apart ( which is what it does at the moment).
All help is greatly appreciated from the new guy!
