Loop through all Dynamic blocks and set the Block property “Allow exploding” to “Yes”
Mike_Y2
Mike_Y2
I regularly receive drawings from a client that contain a dozen or so Dynamic blocks. Each of the Dynamic blocks has the Block property “Allow exploding” set to “No”.
I was wondering if anyone has (or can write) a macro / Lisp that will loop through all Dynamic blocks in the current drawing and set the Block property “Allow exploding” to “Yes”?
Any help would be greatly appreciated
h_s_walker
I found this thread Explode Blocks set to "Allow Exploding = NO" - Autodesk Community - AutoCAD which might help you
Howard Walker
Left Handed and Proud
Libbya
The Dynamic Blocks forum does not really deal with custom code and isn't where coding experts typically hang out.  If you want help with a LISP, then post to the LISP forum.
Mike_Y2
Thanks for the reply. I haven't used Lisp before and I am clearly doing something wrong...
  1. I copied the code from the post you sent me (also shown below) and pasted it into Notepad
  2. Then saved the file as "Test.lsp"
  3. In AutoCAD I went to the "Manage" tab and clicked on "Load Application"
  4. I selected the "Test.lsp" file and clicked on the "Load" button
  5. AutoCAD says it successfully loaded
I am not sure how to run the command / if the steps I did (listed above) are correct???
Can anyone help???
(defun c:expl-p ()
(vl-load-com)
(vlax-for b (vla-get-Blocks
(vla-get-ActiveDocument (vlax-get-acad-object)))
(or (wcmatch (vla-get-Name b) "`**_Space*")
(vla-put-explodable b :vlax-true)))
(princ))
h_s_walker
@Mike_Y2 I have never used Lisp (I'm only on LT), however I do believe the line below defines the command
(defun c:expl-p ()
So at the command line after loading the lisp you need to type EXPL-P
Howard Walker
Mike_Y2
thanks @h_s_walker
