LOOKUP link with tekst attribute
I found several posts about LOOKUP techniques, but couldn't solve my problem.
I have a simple block with 1 tekst (attribute), that tekst need to change without editing the block (FASE / CONCEPT / DEFINITIEF / TER INFO)
So what did i do:
1. I made a attribute definition called FASE.
2. I made a LOOKUP parameter
3. I filled the LOOKUP parameter with (FASE CONCEPT etc.) using the LOOKUP action
4. I made the default in the attribute the LOOKUP parameter ) insert field > blockplacehodler > Lookup1
It doesn't work, what do i do wrong?
I forgot to add the block.
here is the block
Libbya
That file does not have any blocks.  It also does not have any dynamic parameters or actions in it.  It just has two rectangles and an attribute.
