lookup help !!
lookup help !!
lookup help !!
Dear all,
can i do triple lookup in dynamic block ?
Libbya
Yes, you can add as many lookup tables as you like to the lookup parameter tool but I have never found any use for a triple lookup.
triple lookup i used it for cable ladder size, angle & radius, there are many drawing in visibility status and i want to add triple lookup to choose size and radius & angle one by one like this example photo
Libbya
A triple lookup will not give the progressive sub-menus.  The behavior in your picture is done using a block properties table.
thank you for information sir 🙂 , your answer is helpful 🙂
arturo.z.galan
Observer
Observer
do you have some screencast for do this?
I´m trying and trying and trying to do drop-down list with lookup and I cant do this. Please, Help!!!!
