I am still having a hard time wrapping my head around how to correctly set up a Lookup in a dynamic block. What I am intending to do is have a block that uses lookups to create a versatile sheet list set.
I have a "Sheet List" that varies depending on the city we design in. In the block below I have the default options listed: (Cover Sheet, Site Plan, Mount Details, Electrical Diagram) with 2 other inputs which are a second and third layer of variables. #2 (Electrical Notes, Warning Labels, Electrical Notes & Warning Labels), #3 (Electrical Photos, Extra Electrical Photos). I have the visibility states following this format 1 = the default sheets, the second number (0,1,2,3) = the #2 set of variables with the 3rd set of numbers (0,1,2) representing the electrical photos. *Note - 0 always equals "OFF".
I have the visibility states set up how they show look, I am stumped on how to create the lookups at this point. I also am wondering if it is even possible to have the text shown in the right spots with lookups. (That should be apparent when looking through the visibility states.)
Could you possible help provide an explanation of how I need to set this up to work? I do appreciate the time!
