Looking for Help with Dynamic Block and Visibility States
rp_cad_2025
rp_cad_2025
Hi everyone,
I'm trying to create a dynamic block with multiple visibility states to represent different caster sizes. As the base size increases, I’d like the supports to adjust accordingly, remaining evenly spaced. Additionally, I want to automatically add more casters once the base exceeds a certain size.
I've attached a reference image to illustrate what I'm aiming for.
Any guidance or suggestions would be greatly appreciated. Thanks in advance!
Brock_Olly
This is doable, can you show your attempt at creating this dynamic block?
rp_cad_2025
Thanks for the quick reply Brock! So, I have tried different attempts, but they are not working quite right. My first attempt was an array action, but when I try the array, the first (left support drags away from the original position. I also tried doing it with a construction line. I think this one works, but requires two grip,s and I am trying to only have one grip. Not sure if all this makes sense?
PS. I am pretty new on dynamic blocks.
rp_cad_2025
Please see my attempt.
I was wondering if, instead of using an array, the horizontal constraint could be defined by a formula—similar to
((Spacing * 2) * Trunc(d1 / 72)) + 3.25 + (Trunc(Count / 6) * Spacing)
(which is used for the third set of casters)—but with a condition that returns 0 when d1 < 20.
I’m trying to keep the geometries complete so I can extrude them later, and I believe using an array prevents that. Please take a look at my attempt.
