Link text height Property with parameter
Message 1 of 8
Can any one help me how to adjust text height with respect to parameter.
For Ex.:
If i draw a line of 1000mm(Parameter d1) and i entered text "Line 1000" with text height of (d1/100)mm =10 mm.
when i change length paramter d1to 10000mm then text height should change to d1/100=100 mm.
please suggest if is ther any way to link parameter with text properties. Else pleae suggest any solution for this issue.
Thanks in advance.
Accepted solutions (3)
Replies (7)
Message 2 of 8
Libbya
Message 3 of 8
hi Libbya,
Thank you for the response.
I was able to manage with geometry but i want to control the text. i am not able to control the text height with parameter.
please suggest accordingly.
Message 4 of 8
ojuris
hi!
is this what you want?
Message 5 of 8
hi ojuris,
Could you please give me the cad drawing in lower version. i have autocad 2012. can you please convert the drawing as suitable. so that i can check and get back to you.
Message 6 of 8
ojuris
Message 7 of 8
Ya this is the one i am looking for.....
Thanks Ojuris.
Could you please explain me the process how the text is getting bigger and what is the relation you made between text and line length parameter to make the text bigger.
Message 8 of 8
ojuris
I add 2 distance parameters - 1 for line length, 2 for text height - both for size you need (in your case Distance1 is 1000, Distance2 10 (1000/100))
For 2 parameter I add scale action to scale attribute and for parameter switch Chain Actions to Yes
For 1 parameter I add stretch action to change line length and another stretch action with scale factor 0.01 to stretch length of Distance2
After that close block editor mode and for attribute add text and field with line legth
