Hey guys,
I have created two incredibly simple blocks. And both are giving me problems I haven't seen before.
Problem #1 - Linear Stretch
The whole purpose of these blocks is to show the extents of steel and its orientation within a wall. This means it requires 2 key parameter, stretch and rotate. I have tried every possible combination and work around I can think of, and have done this on numerous other blocks (with success). But, when I apply a rotate parameter, it skews the stretch and pulls the block into a funny shape. which, obviously isn't ideal.
Problem #2 - Att Definition
My company keeps all of our common blocks on a tool pallet, for ease of access. So the master .dwg containing all of the pallet-ed blocks typically has preset attributes. i.e. these blocks attributes are set to insert the name of its visibility state as a field definition. This works fine and dandy when inserting and initial use. EXCEPT, after you close and reopen a drawing containing the blocks. This causes the fields to set to "####". I have tried running a regen, regenall, and ATTSYNC. None of these fix the issue.
Any intput would be appreciated, thanks.
ps - the "Steel_Header.dwg" will not contain the attribute definition as it was added to a later rendition of the block in our master.dwg. but the "Steel_Channel" will contain it.
